Announcement
No announcement yet.
Roof Repair Question
  • Filter
  • Roof Repair Question
    Hi everyone,
    I’m facing some issues with my roof and could use your advice. I’ve noticed a few leaks after heavy rain, and there are some missing shingles. I’m unsure whether to attempt repairs myself or hire a professional. Can anyone share their experiences with DIY roof repairs?
    What tools and materials do I need? Additionally, how can I assess whether the damage is minor or if I need a full replacement? Any recommendations for reliable contractors in the area would also be appreciated.
  • #2
    Hi Fejog!
    Welcome to the forum!
    Deciding whether to tackle the repairs yourself or hire a pro can depend on a few factors. If you're comfortable with heights and have the right tools, small fixes like replacing a few shingles or patching minor leaks with roofing cement can be a manageable DIY project. You'd need basic materials like roofing nails, a hammer, replacement shingles, and a good sealant. Just be sure to prioritize safety with a sturdy ladder and non-slip shoes!
    On the other hand, if the damage seems more extensive—like large areas of missing shingles, water stains inside your home, or if the roof is sagging—it might be a sign that the problem is bigger than a quick patch job. In that case, it could be worth calling in a professional to assess whether a full roof replacement is needed. If you're unsure about how to evaluate the damage, a contractor can give you peace of mind with their expertise. If you decide to hire someone, it’s a good idea to ask friends or neighbors for recommendations, or check online reviews to find a reliable contractor in your area. Let me know if you need any more tips or have other questions!
    Thank you!
    • #3
      Originally posted by fejog View Post
      Hi everyone,
      I’m facing some issues with my roof and could use your advice. I’ve noticed a few leaks after heavy rain, and there are some missing shingles. I’m considering a roof leak repair Toronto, but I’m unsure whether to attempt repairs myself or hire a professional. Can anyone share their experiences with DIY roof repairs?
      For leaks and missing shingles, small repairs can be done yourself if you’re careful, but safety is key. You’ll need a ladder, safety harness, hammer, roofing nails, pry bar, roofing cement, and replacement shingles. Check your attic for water stains, sagging, or mold to see if the damage is minor; widespread damage or multiple missing shingles usually means a full replacement is safer. If unsure, hire a licensed, insured roofer with good local reviews. Getting multiple quotes and checking references can save money and prevent mistakes that DIY repairs might cause.
      • #4
        Hi,
        A few missing shingles and leaks after heavy rain can sometimes be a relatively straightforward repair, but it really depends on how extensive the damage is. The first step is to inspect the roof (safely) and look for signs such as missing, cracked, or curled shingles, damaged flashing around chimneys and vents, and any soft or sagging areas. Inside the attic, check for water stains, damp insulation, or visible daylight coming through the roof deck.
        For minor DIY repairs, homeowners typically use replacement shingles, roofing nails, roofing cement/sealant, a pry bar, a hammer, and proper safety equipment. However, working on a roof can be dangerous, and leaks are often more complex than they appear because water can travel before becoming visible inside the home.
        If the damage is limited to a small area and the roof is otherwise in good condition, repairs may be enough. On the other hand, if there are multiple leaks, widespread shingle deterioration, sagging sections, or the roof is approaching the end of its expected lifespan, it may be worth having a professional evaluate whether a larger repair or full replacement is the better long-term solution.
        My recommendation would be to schedule a professional inspection before investing time and money in DIY fixes. A reputable roofing company such as Willow Ash Roofing can assess the extent of the damage, identify any hidden issues, and help you determine whether a repair or replacement makes the most sense.
        Good luck, and hopefully it's just a localized repair rather than a full roof replacement!
        • #5
          For a few missing shingles and minor leaks, DIY is manageable if you are comfortable on a ladder. You will need replacement shingles, roofing nails, a pry bar, roofing sealant, and a utility knife. Simply remove the damaged shingles, slide new ones into place, nail them down, and seal the edges. However if leaks keep returning after every rain, your roof is over 20 years old, or you notice sagging and attic moisture, those are signs you need an Emergency Commercial Roof Repair specialist rather than a quick fix. For finding a reliable contractor, ask neighbors for referrals, check Google reviews, get at least three quotes, and always verify their license and insurance before committing. Avoid anyone asking for full payment upfront. Bottom line, minor isolated damage is fair game for DIY but persistent leaks combined with missing shingles usually point to a bigger underlying issue worth having a professional evaluate before it turns into a costly interior damage problem.
