Home renovation
  • Annahmed
    • 223
    Home renovation
    Hi everyone! I have peeling paint on the lower parts of my living room wall, likely due to moisture, and I’m considering ways to hide or fix it. I’m thinking of using wallpaper or repainting, but I’m open to other ideas. What are some creative solutions to cover or repair this area effectively while preventing future moisture damage? Thank you in advance!
  • FatimaandAhmed
    • 343
    Hi there! One creative solution to cover peeling paint while addressing moisture issues is to install wainscoting or decorative paneling on the lower part of the wall. This approach not only hides the damaged area but also provides a barrier to moisture, which can help prevent future issues. You can choose materials that are moisture-resistant, such as vinyl or treated wood, which are both durable and stylish. Another option is to use moisture-resistant wallpaper designed for high-humidity areas. There are modern wallpaper options with washable, waterproof finishes that are perfect for areas prone to moisture, allowing you to cover the peeling paint and add a decorative touch at the same time. Both of these ideas can effectively cover the damage while offering added protection against further moisture buildup.​
    • Downaski
      • 409
      I’d like to add a couple of unique ideas that might be worth considering as well. One option is to apply a textured or faux plaster finish to the lower part of the wall, which can not only cover up the peeling paint but also add a bit of character to the room. You could even try a stucco or Venetian plaster effect that is moisture-resistant, which would help with both aesthetics and functionality. Another idea is to install an accent or feature wall using large decorative tiles, which are great at resisting moisture and will also give your room a fresh, modern look. These approaches could really add something special to the space while addressing the issue effectively.
      • TinyTool
        • 357
        Great suggestions so far! Here are some more suggestions:
        • PVC wall panels: These are lightweight, waterproof, and easy to install. They come in various designs and can give a sleek, modern touch while effectively protecting against moisture.
        • Peel-and-stick wall planks: If you're looking for a quick and stylish fix, peel-and-stick wood or vinyl planks can create a cozy accent while covering the damaged area. Some options are even water-resistant.
        • Exterior-grade paint with a moisture barrier: If you prefer repainting, using a high-quality exterior paint with mold and moisture resistance can help prevent future peeling.
        No matter which option you go with, addressing the moisture source first is key to ensuring a long-lasting fix. Hope this helps!
        • Annahmed
          • 223
          Thank you all for the great suggestions! I appreciate the variety of ideas, from wainscoting and wallpaper to textured finishes and PVC panels.
          Before repainting, would applying a moisture-resistant primer or sealant help improve durability and prevent future peeling?​
          • Downaski
            • 409
            Absolutely! Using a moisture-resistant primer or sealant can definitely help keep your paint job in good shape longer. It creates a protective layer that prevents moisture from seeping in and causing the paint to peel.
            • Annahmed
              • 223
              Actually, the wall doesn’t seem wet, it’s just the paint peeling off. Could this still be due to moisture, or might it point to another issue? The peeling is only affecting the bottom part of the wall, so I’m wondering if it could be linked to moisture rising from the ground. What are your thoughts?
              • TinyTool
                • 357
                Yes, it can be caused by moisture, even if the wall itself doesn’t feel wet. One possibility is rising damp, where moisture from the ground travels up through the wall due to capillary action, especially if there's no proper waterproofing or if the foundation lacks a vapor barrier. Over time, this can cause paint to bubble, crack, or peel.
                There could be other causes too, such as poor surface preparation before painting, leaks or plumbing issues, and condensation buildup.
                If it is due to rising damp, you may notice white, powdery residue (efflorescence) or consistent peeling along the lower section of multiple walls. If moisture is the cause, solutions could include improving drainage around the house, sealing the foundation, or using moisture-resistant paint.
                • Annahmed
                  • 223
                  Not sure about the powdery residue, but yes, it has affected multiple walls. I’m curious though, how can you address foundation issues like that after the house is already built? Is it possible to fix moisture problems in the foundation, or would that require major work?
                  • TinyTool
                    • 357
                    Fixing moisture problems in a house's foundation after it's built is definitely possible, though the level of work depends on how serious the issue is. One of the first things to check is drainage around the house. You’ll want to make sure the ground slopes away from the foundation and that gutters and downspouts are working properly to move rainwater away. If there are cracks in the foundation, sealing them with the right sealant can stop moisture from getting in. For homes with crawl spaces or basements, improving ventilation can help keep moisture levels in check. Adding vents, a vapor barrier, or using a dehumidifier can all be helpful.
                    If the moisture problem is more serious, you might need to waterproof the exterior of the foundation, which involves excavating around the house to apply a special coating. In the worst-case scenario, stabilizing the foundation with underpinning might be necessary. It's always smart to have a professional take a look to determine the best solution for your specific situation.
                    • Annahmed
                      • 223
                      This is really helpful, thanks! I’m curious about the underpinning process you mentioned. How exactly is it done, and does it impact the people living in the house while the work is being done? I'd imagine it might be a big job, so I’m wondering how disruptive it can be.
                      • TinyTool
                        • 357
                        Underpinning is basically a way to reinforce a home’s foundation, usually by digging underneath and extending it deeper to more solid ground. It’s done in sections to keep the house stable, with concrete poured in stages to strengthen everything.
                        As for how disruptive it is, it really depends on the scale of the work. If it’s a smaller job, like reinforcing certain areas, you might be able to stay in the house, though there will be noise, dust, and some vibrations from digging. But if it’s a major underpinning project, like lowering the whole foundation, you might need to temporarily move out. Either way, it’s definitely something to discuss with a structural engineer to get a better idea of what to expect.
                        • Annahmed
                          • 223
                          Thanks! How long does this process usually take, TinyTool?
                          • TinyTool
                            • 357
                            The duration of underpinning depends on factors like the foundation size, soil conditions, and the method used. For a small-scale project reinforcing specific sections, it might take a few weeks. However, if you’re underpinning an entire house or lowering the basement, it can take several months.
                            A structural engineer or contractor should be able to give you a more accurate estimate based on your specific situation!​
                            • Annahmed
                              • 223
                              #15
                              Got it! Thanks for the info!
