Reusing cardstock stencils
  • Reusing cardstock stencils
    Hi everyone! Are cardstock stencils reusable?
    Hey! Yes, cardstock stencils can be reusable, but it really depends on how carefully you use them. If you're using them for small projects or with paints that don’t soak through too much, you should be able to reuse them a few times. Just make sure to clean them gently after each use, so they don’t get too worn out. If you're working on a larger project or using heavier materials, the cardstock might start to wear down quicker. Hope that helps!
      Thanks for the info! Do you think certain types of paint (like acrylic vs. spray paint) would wear them out faster, or is it more about how thick the application is?
