Recommended primer for new drywall before painting
  • Downaski
    • 409
    Hi,
    What type of primer is recommended for use on newly installed drywall to ensure the best results before painting?
  • Tomhanks
    • 193
    Hi!
    For newly installed drywall, it’s a good idea to start with a drywall primer-sealer or a PVA (polyvinyl acetate) primer. These are made specifically to seal the surface and the joint compound, which helps create a smooth, even base before painting. That way, the paint sticks better and goes on more evenly, without soaking in too much in some spots. It can also cut down on how many coats of paint are needed. Regular latex or oil-based primers that aren't meant for drywall usually don’t seal the surface as well, so it’s best to avoid those. A good drywall primer really makes a difference in how the final paint job turns out.
    • Downaski
      • 409
      Thanks! For fresh drywall, does a sprayer or a roller give better results when applying primer?
      • Tomhanks
        • 193
        Both a sprayer and a roller can give good results on fresh drywall, but the choice often depends on the size of the job and the finish desired. A sprayer covers large areas quickly and lays down a very even coat, which is helpful for new drywall throughout an entire room or house. However, spraying requires more prep work to protect surrounding surfaces from overspray.
        A roller takes more time but is easier to control and doesn’t require as much masking off. It also works primer into the surface slightly, which can help with absorption on new drywall. For many smaller projects or single rooms, a roller is often more practical, while a sprayer can be very efficient for bigger jobs.
        • Downaski
          • 409
          Thanks! Do certain types of topcoats perform better over a PVA primer, or is the difference minimal?
          • Tomhanks
            • 193
            Most standard interior paints perform well over a PVA primer, so the difference is usually minimal. PVA primer is mainly there to seal the fresh drywall and give the topcoat a uniform surface to bond to. Both flat and eggshell finishes tend to go on smoothly over it, and higher-sheen paints like satin or semi-gloss also adhere just fine. The main thing is to make sure the primer is applied evenly and allowed to dry properly before painting. If you’re using a specialty topcoat, like a moisture-resistant bathroom paint, it will still work well over PVA primer as long as the surface is properly prepared.
            • Downaski
              • 409
              One last thing, is it worth applying two coats of primer on fresh drywall, or is one coat usually enough?
              • Tomhanks
                • 193
                One coat of primer is generally sufficient for fresh drywall when applied with full and even coverage. Drywall primers, particularly PVA primers, are designed to seal the porous surface and create a uniform base for paint in a single application. In cases where the drywall is highly absorbent, the surface appears blotchy after priming, or there are noticeable differences between the paper surface and joint compound, a second coat may help achieve a smoother, more consistent finish. A second coat can also be beneficial when a light or bright topcoat is planned, as it enhances color uniformity. Under normal conditions, however, one well-applied coat of primer provides an adequate foundation for most interior paints.
                • Downaski
                  • 409
                  Thanks for all the info! Really appreciate it.
