drywall
This topic is closed.
  • senetsomed
    • Feb 2004
    drywall
    I installed drywall and the joints were not properly sanded, and then painted the room, but now I want to fix it, how can I do it?
    Block sand the high spots. You could also use a paint scraper. I'd scrape as much as I could to get slightly below the wall surfces on either side. Then do the joint right with the tape and joint compound. Get one of those 'Handy-How-To' books from one of the box stores on the method of joint filling. You'll need three sizes of spatulas. You'll be pleased with the outcome.
    • Troy
      Moderator
      • Jul 2002
      • 576
      See this post:
      Try
