How to repair a Loose Toilet Paper Holder
  • zhshqzyc
    • Jun 2011
    • 6
    Hello,
    My bathroom toilet paper holder is danglering on the wall. I removed the screw and anchor, replaced a big one. However, it didn't work at all.
    The hole was enlarged and the anchor was dropped down into the hollow space which likes a black hole.
    How to fix it?
    Should I repair the drywall?
    Thanks.
    use a fastener called a "toggle bolt." this has a long screw with a nut that springs open within the hollow wall space.
    • Drywall DIY Guy
      • Jan 2005
      • 108
      TP Holder Repair
      The toggle bolt is the quick thing to try first. If that does not work, then you can get a very sturdy solution by cutting out a drywall square bigger than area, putting in backing strips, and then placing a patch piece attached to the backing strips, making sure that the backing strips are in the location of the screws holding on the TP holder. Finish, prime and paint. For a small hole in the middle of a sheet of drywall, taping is not needed since no cracking will occur on the seam. A detailed procedure for this is given at Drywall Repair a Hole in Drywall - Instructions
      http://drywallinfo.com
