Hello,
My money pit threw a real curveball at me...
House is a "raised ranch" (late 60's split level) with the first floor on-grade. We are on the side of a hill and have some runoff issues that cause springtime ground water levels to be fairly high, and we live in a very humid microclimate in the summer in centeral NJ. We've been in the house 1 year and we're in the process of refinishing the garage and first floor ceiling after replacing the entire HVAC system due to an undersized ductwork problem and issues with the electrical. We gutted the ceilings and replaced everything, and gutted the entire garage (which is under the living space), insulated with spray foam, and are in the process of replacing the wallboard.
Problem we hit is that there has been a musty smell in the basement, which I was hoping would go away with the HVAC fix and a newly airtight garage. It didn't and when vacuuming I hit the floor molding and a huge hole popped in the molding... it was rotted clean through. The drywall was damp and weak... spongy. I wound up ripping out that one wall since I'm already knee deep in wallboard.
I found that there were studs on the concrete foundation, which goes up about 3 feet from grade, with unfaced insulation and 6mil poly vapor barrier under the drywall. The vapor barrier was on the drywall side, holding the insulation between the barrier and the concrete block. Well, there was obviously a long standing problem with moisture trapped in this space, as the wood studs were all completely rotted out. I pulled them out in handfulls of rot. Behind the vapor barrier it was damp, so was the insulation. Not so much mold on the insulation, and a small amount of mold on the drywall, it looks like condensation dripped down the vapor barrier, accumulated on the wood, and wicked into the drywall. The mold was limited to about 2" on the back of the drywall, whereas the sponginess went up about 2 feet.
SO how do I fix this? I am thinking of DryLoc or some other heavy solid watersealing on the concrete, and then putting metal studs and poystyrene foam panels as insulation, and then putting up the green mold-resistant drywall on those studs. My second inclination is to skip the dryloc and the insulation and simply do metal studs and drywall (green).
I read highly conflicting advice on which side to put a vapor barrier on so I'm inclined to use foamboard if I do use any insulation... would it work well with dryloc or would the two combined cause moisture problems? Should I just let it air and use nothing?
Pics attached.
Any advice?
Pics attached.
Any advice?
