Is there a type of wallpaper desined to be painted over? Maybe if there isnt there should be. For instance a brown paper or white that could be used as a cover of old paper then just painted over, instead or removing years of old paper
paper
If you do not want texture, ask for wall liner - also known as blank stock.
For best results hang horizontally.
I would recommend an oil base primer before painting.
You do not want the water in a water-based topcoat reactivating the wall covering adhesive.
There is also a line of fiberglass wall coverings available that are textured, breathable and paintable.
That said, it is usually best to remove the paper
I agree, it is best to remove the paper. What if you try to get the paper down and you take sheetrock with it, that is what happened to me last week. So I bought some border to border adhesive started puting the new wallpaper on top. it is beautiful , sometimes you just have to cover the walls up with something you can paint, because yousure cant paint torn up walls!!!!
by AshRaeI have a hole in my wall about the size of a doorknob (oops) — is there an easy way to fix this myself or do I need to hire someone? First time dealing...
Channel: Walls and Wall Coverings
by eurroexportI want to hang shelf on wall but wall sounds hollow when I knock on it, not like the brick walls back home. how I hang something heavy on wall like this...
08-21-2026, 03:47 PM -
by BodreyI'm renovating my house right now including installing new drywall. Just today, I started taping the living room, but now I'm seeing that some of the...
