Paint Removal from Fireplace
  • Bonnie Ryan
    I have several layers of paint on a fireplace that I would like to have removed. Can you tell me the best way to do this. I believe there are both latex and oil base paint layers. Any help would be greatly appreciated.
    Thank you, BR
    B. Ryan
  • kactuskid
    • Mar 2004
    • 801
    If it's brick, then the only way I know of to remove it from all the pores is to have it sandblasted. Of course this could also damage the brick. You'd be better of repainting it. Here's a couple of links that may give you some ideas
    Ron Hazelton Home Improvement Online is your how-to resource for straightforward DIY help. Learn from our step by step project tutorials and DIY videos.
    http://tlc.discovery.com/fansites/tr...roject_08.html
      Here's the 'before':
      Here's the 'after':
      Kactus is right. Sandblasting's the way to go. Tape off the area with plenty of sheet plastic...get a nice saftey hood and protetion and you're good to go. As he said, be careful with that sand blaster, it could etch the brick more than you'd like. This brick was very old and very soft, but cleaned up quite nicely. You can vary the impact of the sand by the amount of air pressure as well as distance from brick. Hold it close enough/long enough to wear away the paint. When your done....shopvac up the sand real good and your set. What I like about it is there's no chance of acids damaging flloring or splashing where you don't want it. Not haveing to rinse it away. And the brick is much ckleaner. (I think...).
      • colima
        Have Sean do it for you!
        • sammyt
          • Nov 2004
          • 5
          Forget removing the paint. Use Brick-Anew and paint over it. It will be 10 times easier and will probably look better too. Brick-Anew is a brick fireplace paint that comes in a DIY kit. Check them out at http://www.brick-anew.com.
          SAM
