I just bought an old house with radiators. Can I paint them with the same paint that I used on my walls? Or do I need something special?
Painting Radiators
If the radiators have never been painted, they probably should have an oil based metal primer on them first. After that you can put on whatever topcoat you like. Handyandy is right about oil-based top coats discoloring, but you're probably using latex for your walls and trim anyway.
You can also get a bent paint brush (looks like a small hockey stick) or a thin roller that will make the job much easier.
leone184leone184Comment
