Hi everyone,
We've moved into a 1925 colonial house in Northern NJ and I'd like to re-hang the iron pot-rack we had up in our old house. I think the walls are plaster over lathe, which explains why my stud-finder gives odd results. However, the inspector told us the house was "balloon construction", that it was 2x4 studs with brick in-between and I presume he meant that was the exterior walls, not interior - but I don't know this for sure.
How should I proceed? Can I safely measure from the edge of a doorframe 16 inches, drill and hope that I hit a stud? Should I try to find an industrial stud finder (to rent, I hope)? If I find studs, should I mount the pot rack directly to them, or should I mount an oak board to the wall and mount the pot rack to that? Is drilling holes in the wall the only way to know if it is brick or lathe under the plaster?
Thanks so much!
