Load bearing or not?
  • Load bearing or not?
    hello- can someone tell me if you think this is load bearing or not? I want to saw away those pieces of wood and then re-drywall it it. There was a recessed fluorescent light in there and I want to open it up-
    What do you think? Is it safe to saw?
    Load bearer
    I presume you did not remove any verticals? Sure doesn't appear to be a load bearing beam. I would think the wall would be more of the load carrier and this was just a means of providing a frame to hang the drywall on. Just my suspicions...
      Its not load bearing, the 4x4 is a method of insuring a stable soffit line.
      Cut it out carefully as it appears to be continious members of the soffit.
      If cracking appears and the member/s are loose you will need to remove more drywall and add nailing.
      Illegitimas non-carborundum
        K- I removed the soffit
        ....next Drywalling!
          Load issue....
          Clean and neat. Should be a lark from here on to get the lights you want up and running. Sure will open that area up.
            Yes, I have the track lighting that will suit the bathroom area-
            IT came with these little collasible prongs that go thru the ceiling and then spring open, I'm realizing that once they are thru - that's it- I would have to remove the ceiling. SO I will either have to do it perfectly the first time or figure out how to screw it in securely enough to support the weight of the fixture.
              Your links, both screw and fixture, are to web sites, not product.
                yeah, this site generates those automatically- i had nothing to do with it-
                if you want to see the fxture I got it's on homedepot.com
                it's a hampton bay floating glass track light- http://www.homedepot.com/prel80/HDUS...4+4233&pos=n12
