Hello,
My husband and I are in the midst of a major home renovation project, and much to our dismay, our plans have been delayed due to peeling paint in the master bedroom. It seems that layer upon layer of paint was applied over the years--no idea what type, etc. A few areas were chipped so my husband began scraping and sanding to smooth the walls before applying new paint... but the more we scrape, the more paint comes off! It seems like on the walls there comes a point where the paint stops peeling eventually, but the ceiling paint comes off in large flakes with little prodding. I don't know if there was water condensation on the walls/ceiling at one point, or what, but that is possible; there was some water damage to the ceiling and the two worst walls are an outside wall with large windows and the area next to the bathroom door.
My question: how to know when we are through scraping? Should we scrape as much as humanly possible off the walls even if the paint doesn't seem "loose" or damaged in some areas, or is it only necessary to take off whatever comes down after a quick once-over with the scraper and then just sand the whole wall smooth and repaint? I don't want our new paint to be peeling off! On the other hand, it is taking FOREVER to scrape the old paint and some of it really doesn't want to come off...
And is there an easier way to do this other than using a small hand-held scraper? Especially on the ceiling, which as I mentioned, the paint comes off in strips. Seems like there should be a quick solution to that but it takes forever just because the tool is only about 2" wide.
I would sure appreciate any suggestions. I'll probably be on this forum a lot now that I've discovered it! We have many questions, and a house desperately in need of some love
