In my bedroom in the summer time when its hot I run a small window AC.Around the ceiling tiles and molding there is moisture.What would cause this?
Ceiling sweating in summer time.
where there is moisture with an air handling system the culprit is a [difference of temperature."inside an airconditioner, the suction line is always colder than the surrounding air - that's why it drips water. outside of the airconditioner the discharge air is colder than its surroundings - that's why you see moisture. must be your airconditioner is set to max cold. throttle it down a bit.
