New wallpaper, wall covering tool, a must have
  • rmguz42
    • Jul 2007
    This is an FYI
    Problem:
    When a person hangs vinyl wallcovering it is hard to get tight inside corners and tight outside corners. These two items alone will drive a paper hanger or a contractor crazy. If you use a 6” Flex blade you’ll cut the corners like a knife, if you use a trowel you can’t get enough pressure on it to tighten the corners, Wall Wiz (no longer manufactured) not heavy enough to get a tight corner, 6” stiff blade is probably the best solution to all of these problems (but very time consuming) and the good ones are no longer made so they are virtually non existent. There is a better solution. I just purchased a Big Boy Wallpaper smoother, it is made of stainless steel and is a great tool to have when you are hanging wallpaper. If you are interested in getting one send me an email and I will send you the address of where you can get one. If you need more info email me at rmguz@juno.com Believe me, I have been hanging wall coverings for over 29 years and you do not want to hang without this Big Boy. Good luck hanging.
