I am painting my family room segovia red. This is a very bright room, plenty of sunshine. The window trim and mouldings will be white. This room has baseboard heating on three of the four walls (4 inches high). Should I paint the boards to match the walls or paint them the same as the trim.
should baseboard heating be painted
I have often had to "refinish" base board heaters. my paint of choice is rustolium spray paint but any "good quality" enamel spray paint will work.quote:Originally posted by Lynnmac
heres what I do:
first turn off the circut breaker to the heaters to be painted.
2nd mask off or remove the heating element and mask surrounding walls/floors.
3rd,lightly sand all serfaces to be painted
4th,wipe down all serfaces to remove any dirt or dust
5th paint spraying in even strokes
6th re-coat if nessary and let dry at least 24 hours
hope this helped.TAZ
nuthing like being woken up at 12:AM to unstop some one elses toilet.nuthing like being woken up at 12:AM to unstop some one elses toilet.Comment
by AshRaeI have a hole in my wall about the size of a doorknob (oops) — is there an easy way to fix this myself or do I need to hire someone? First time dealing...
Channel: Walls and Wall Coverings
by eurroexportI want to hang shelf on wall but wall sounds hollow when I knock on it, not like the brick walls back home. how I hang something heavy on wall like this...
08-21-2026, 03:47 PM -
by BodreyI'm renovating my house right now including installing new drywall. Just today, I started taping the living room, but now I'm seeing that some of the...
