Every year at this time we suffer with some wallpaper comming away from the wall i use strong paste when putting it up, i let it dry for seven days then paint it with a good quality paint, it stays put till autumn, then it starts to bubble in places then comes away from the wall, no matter what i do to stop it,( haven't tried nailing it YET) can anyone advise me thank you.
wallpaper falling off wall
good tips Hayzee and I agree on both counts.
If you are really wanting to paint it you have to consider removing the wallpaper. Paint companies will not recommend painting over wallpaper. The reason is that the paint could react with the glue and poof peeling wallpaper. I would remove, prime and paint. done.Comment
by AshRaeI have a hole in my wall about the size of a doorknob (oops) — is there an easy way to fix this myself or do I need to hire someone? First time dealing...
Channel: Walls and Wall Coverings
by eurroexportI want to hang shelf on wall but wall sounds hollow when I knock on it, not like the brick walls back home. how I hang something heavy on wall like this...
08-21-2026, 03:47 PM -
by BodreyI'm renovating my house right now including installing new drywall. Just today, I started taping the living room, but now I'm seeing that some of the...
