I have solid foundation walls on each side of my house that are leaking because the previous owner allowed the gutters to drain inward and the ground sunk in towards the house.
I was going to rent a back ho and dig a trench around the house and water proof it.
I could not find a web site that answered all my questions. If you know of one could you please post it?
Some questions I have is what is the ideal long lasting sealant or membrane I should use and where would I purchase it?
Should I use hydraulic cement to fill the cracks or an asphalt product sealant?
When I back fill it should I use, sand, gravel, rock because it will drain faster and relieve water pressure?
The house is about 8 years old, has sump pump and drainage system underground.
