For cosmetic reasons, I just finished scraping and resealing around the shower door frame. After tackling that I decided to scrape and reseal around the base of the shower. When removing the old caulk I noticed a bit of dampness under the seal and grout cracks where water penetration has gotten in. Now I'm into removing old grout! EEK!
What should I use to fill the larger gaps in all corners of our shower stall? Is there a type of air can I can use before applying the grout and caulk? It doesn't seem like the deep spaces were filled enough to stop the grout cracks from occurring. Also, which is the best silicone caulk to use? I have been using anti-bacterial microbeaded silicone that states "lasts 30 years". I want to do this right.
HELP!!!
It's appreciated!
Thanks for reading!
HELP!!!
It's appreciated! Thanks for reading!
