My parents own another house and rent it out.
The most recent tenants were very neglectful and my dad knows very little about home repair so the house was left in very poor condition for several years.
We finally got the tenants out and I pulled some wall paper off in the living room above the fireplace is to do some painting and found a hole in the drywall.
I opened the hole a little wider to find carpenter ants chewing away the frame of the house.
I have images that i took but this is my first post so i am not allowed to put images apparently
We called the exterminator, he fumagated the whole house.
We went back in a few days later to find more ants so we called him again to do a second fumagating.
It's been a few weeks we have not seen any ants anywhere so we began repairing the hole.
We put the treated wood on fiberglass insulation.
The original insulation behind the wood is a styrofoam but we did not have any on hand at the time. I'm not sure if that will cause problems, behind the wood is just brick and mortar.
We talked to people at home depot about what measures we should take they suggested building a sub frame to support the ceiling while we remove all the wood and replace it.
My question is, is it necessary to remove all the wood in that area, or can we put another 2"x8"x8' piece of wood in front and screw it in place and then patch it up? What would you reccommend.
THANKS GUYS!
THANKS GUYS!
