Can anyone tell me the process which I must use to paint a metal roof? It is in good shape...just want to change the color. Same with the siding.Thanks!
Metal Roof Paint/Vinyl Siding Paint
I painted the aluminum siding on our house. I first used a pressure washer to clean any surface crud off. There's a good cleaner available for this. Then I used another product in the pressure washer that etches the paint. Preps it for the new coat. Was really impressed with it. All those products are available at the local box store. I got mine from HD.
by AshRaeI have a hole in my wall about the size of a doorknob (oops) — is there an easy way to fix this myself or do I need to hire someone? First time dealing...
Channel: Walls and Wall Coverings
by eurroexportI want to hang shelf on wall but wall sounds hollow when I knock on it, not like the brick walls back home. how I hang something heavy on wall like this...
08-21-2026, 03:47 PM -
by BodreyI'm renovating my house right now including installing new drywall. Just today, I started taping the living room, but now I'm seeing that some of the...
