I live in southern Wisconsin and just had 18" of backed up storm water in my basement (not sewage thankfully). Aside from all the appliances that need replacing I have a question about the drywall & insulation in the finished portion of the basement. The wet sheet rock had to be cut and pulled out about 30" from the floor. ALL the insulation that was behind all of the sheet rock was pulled out since the wet part had compressed and then the insulation above it fell lower into the wall cavity and also got wet. The remaining sheet rock & studs appears to be drying out quite well now.
This "finished" part of the basement is no longer directly heated from the furnace and is only used for storage. Would it be a problem to just replace the removed sheet rock without bothering to replace the insulation?
