I'm currently renovating my house, which I thought was built in the 40's. But after doing some remodeling I found some newspapers in the wall dating 1910.
The 2x4 studwalls are 24 oc. My question is - on the interior of the house they have some rough cut lumber on all of the walls 3/4'' thick and 4-8'' wide. This is the same material they as sheathing on the outside of the house. On the inside they used a "decorative wall board" which we found under some paneling and sheetrock. It was basically just a thin piece of cardboard with a design printed on it. And they blew insulation into the walls with my best guess sometime in the 40's when they added an addition on and resided the house.
Just curious if the rough cut lumber on the interior is anything I should leave up? I would like to take it down because the insulation has settled and there is cold spots. I have to rewire the house, and I'd rather do it with out having to try to keep the old insulation in tact. I would then sheet rock the walls. Anyone ever seen this rough cut lumber on the inside of a house before? Is it something I can take down? or will it effect the structural integrity of the walls?
Attached is a picture of the 2nd floor.
Thanks!
Thanks!
Those are the walls I want to insulate.
