Can you glue drywall instead of screwing or nailing?
  • Downaski
    • 409
    Hey everyone!
    Is it okay to glue drywall instead of using screws or nails? What kind of adhesive would give a strong, lasting hold? Any tips or things to watch out for when gluing drywall to studs or walls?
  • nimmi1231
    Banned
    • May 2025
    Yes, you can glue drywall, but it's best to use adhesive along with a few screws for long-term stability. Products like Liquid Nails or Loctite PL Premium work well.
    • Downaski
      • 409
      Thanks for the tip about using glue with screws! Do you find that gluing drywall actually helps prevent cracks or nail pops? And does it work better on certain types of studs or walls?
      • FatimaandAhmed
        • 343
        Hi, Downaski!
        Using glue with screws can definitely reduce nail pops and cracks because it keeps the drywall firmly bonded to the studs, minimizing movement. It tends to work well on both wood and metal studs, but it’s especially helpful on wood since they can expand and contract more with humidity changes. Just make sure to use the right adhesive made for drywall and apply it evenly. Also, don’t skip the screws, glue alone isn’t enough for strong, lasting support.
        • Downaski
          • 409
          Thanks for the information. Also, is it common to apply adhesive along horizontal seams, or just on the studs?
          • FatimaandAhmed
            • 343
            Adhesive is typically applied only to the studs (or joists in ceilings) rather than along horizontal seams. The main purpose is to secure the drywall to the framing and reduce movement that leads to nail or screw pops. Applying glue to the seams wouldn’t really add much strength, since there’s no framing behind those areas to bond with. So sticking to the studs is the way to go!
            • Downaski
              • 409
              Thanks, that makes sense. Wondering if adhesive is commonly used on ceilings too, or if most people skip it. Does it actually help with preventing sagging and nail pops up there?
              • FatimaandAhmed
                • 343
                Yes, adhesive is definitely used on ceilings, especially in areas prone to sagging or nail pops. It can make a real difference by keeping the drywall firmly attached to the joists. Applying it overhead can be a bit messy, so it helps to use a caulking gun with a precision tip and work in small sections. Wearing goggles and a mask is a good idea too. Overall, using adhesive on ceilings can really improve the durability and reduce future repairs.
                • Downaski
                  • 409
                  Appreciate the tips, sounds like the ceiling glue is worth the extra effort. Thanks again for the help!
