Hey everyone, what are the pros and cons of using hidden fasteners for deck boards on a pressure-treated frame? How well do they hold up over time compared to face screws, especially with seasonal changes? Thank you in advance!
Are hidden fasteners a good choice for deck boards?
Hi Tomhanks, hidden fasteners give a cleaner look and make the deck surface smoother, which is great for walking barefoot. They work well if the boards are straight and dry. But with pressure-treated wood, which tends to move more with seasonal changes, hidden fasteners can sometimes loosen or allow the boards to shift. Face screws usually hold better over time, especially with wood that expands and contracts. They're also easier to remove if you ever need to replace a board. So it's really a trade-off between appearance and long-term durability.
Yeah, cupping and warping can be more noticeable with hidden fasteners, especially on pressure-treated wood. Since the fasteners usually grip the sides of the boards instead of holding them down from the top, there's less force keeping them flat. If the wood starts to dry unevenly or twist with seasonal changes, hidden fasteners don’t always hold it in check as well as face screws do. That’s one of the trade-offs: nicer look, but sometimes a bit more movement.
It’s more about allowing movement rather than the fasteners popping out. Hidden fasteners usually stay in place, but because they hold the boards from the sides, they don’t resist upward or twisting motion as strongly as face screws. So if the boards start to cup or warp, the fasteners might not stop that from happening as well as top-down screws would.
Composite boards tend to be more stable than pressure-treated wood when it comes to expansion, contraction, and moisture-related movement. Hidden fasteners usually work better with composites because the boards don’t cup or warp the same way wood can. Most composite decking systems are actually designed with hidden fasteners in mind, and they hold up well over time.
That said, composites still expand and contract slightly with temperature changes, especially along their length. As long as the fasteners are installed according to the manufacturer's spacing guidelines, they usually perform well and maintain a clean look without the same concerns you’d have with natural wood.
I replaced my PT deck in 2013. It was rotting out in places. I used Azec PVC decking with a combination of Timber Tech & Tiger Cl;aw fasteners. I bought a Tiger Claw installation tool which made things easier. After you fasten the first board down, the tool forces the Tiger Claw fasteners into the edge of it. The fasteners are held down with special screws. The next board is forced onto the fastener prongs with a block & a big hammer. The PVC is holding up pretty well. It does scratch, so trim your dogs toenails. The PVC is also expensive, but it won't rot. I got the best deal from Lowes.
Thanks for sharing your experience. PVC decking like Azek seems like a good choice for avoiding rot and keeping maintenance low. The Tiger Claw fasteners and that tool you used sound like they made things a lot easier and gave a nice clean look.
Just wondering, have you noticed any fading or color changes over the years, especially in spots that get a lot of sun? That’s something people usually ask about when looking into these materials.
Really appreciate you jumping in with the info.
