Deck board spacing
  • Alpha
    • 194
    Deck board spacing
    Hi everyone!
    When installing a new deck, how far apart should the deck boards be spaced? Does the ideal gap change depending on the type of wood or the local climate?​
  • FatimaandAhmed
    • 343
    Hey there,
    A good rule of thumb is to leave about a 1/8 to 1/4 inch gap between deck boards. That gives the wood room to expand and contract with changes in weather.
    The gap can depend on the type of wood and the climate. For example, if you're using wet pressure-treated lumber, it’ll shrink as it dries, so you might place the boards closer together at first. On the other hand, dry wood or composite boards usually need a consistent gap since they don’t change much.
    If you're in a humid or rainy area, a slightly wider gap can help with drainage. Just make sure it’s not too wide so things don't fall through.
    Hope that helps!
    • Alpha
      • 194
      That makes sense! Do you have a preference between pressure-treated wood and composite boards?
      • FatimaandAhmed
        • 343
        Both have their pros and cons. Pressure-treated wood is more budget-friendly and easy to work with, but it needs regular maintenance like sealing or staining to prevent rot and splitting over time. Composite boards cost more upfront, but they’re low-maintenance and don’t warp or splinter like wood.
        If you're looking for something that lasts with minimal upkeep, composite is a solid choice. But if you're okay with a bit of maintenance and want to save on cost, pressure-treated wood still does the job well. It really comes down to your budget and how much time you want to spend on upkeep.
        • Alpha
          • 194
          How long does pressure-treated wood usually last if it’s maintained properly?
          • FatimaandAhmed
            • 343
            If it’s properly maintained, pressure-treated wood can last anywhere from 15 to 20 years, sometimes even longer. The main thing is to keep it sealed, clean, and free of standing water or debris. Regular upkeep like staining or sealing every couple of years really helps extend its life.
            • Alpha
              • 194
              Thanks again! Great advice all around.
