Galvanized Fence gate on a slope & Size of gate posts
  • Galvanized Fence gate on a slope & Size of gate posts
    I bought a single gate 42 x 48 from Lowes.
    I am going to install it in the corner at the top of our property that slopes back down. I dug the hole today. The 1 5/8" diameter galvanized fence post is 41" above ground, and so far the post I am installing sits in the new hole at 43" above ground. The corner post is not absolutely perpendicular.
    I have a number of questons.
    1. Is there a problem using ( reusing ) a 1 5/8" diameter galvanized for the gate?
    2. does it matter if the gate opens downhill into the property or opens uphill into the property?
    3. If I install the new post, and it set it with concrete to match the angle etc. of the exiisting post, will this work.
    4. Are there any rules of thumb for installing a gate on a slight slope?
    Most harware seems to point to using the 2 3/8 ( or whatever ) larger for the gate entrance....is this the only way to do it....
    I am putting this gate in to be able to get the canoe in and out without having to heave it on the fence.
      1. Is there a problem using ( reusing ) a 1 5/8" diameter galvanized for the gate? NO
      2. does it matter if the gate opens downhill into the property or opens uphill into the property? Should swing open on the downhill side, otherwise you'll have to dig into the uphill to allow it to open fully.
      3. If I install the new post, as it set it with concrete, to match the angle etc. of the existing post will this work. Yes
      see above answers
        pushkins is right
          When dealing with a sloped yard, choosing the right gate design is just as important as picking strong posts to support it. Many people pair their wood fencing with a gate that’s either stepped or angled so it can open smoothly without dragging on the ground. The size and strength of the gate posts matter too, especially on uneven land, because they keep the gate stable and prevent sagging over time. With the right setup, a wood gate can stay sturdy, even on a tricky slope.​
