I would like to build a deck this spring. The side of my house is brick and I am not sure what the best way to anchor it to the house is. The deck will be outside of a second story room.
anchoring ledger to brick
Anchor your ledger board to the house using 1/2" diameter x 4" long (min. I normally use 5") masonry bolts. Depending on the deck size you will need the anchor bolts spaced out no greater than 6' but much better at 4' spaces.
Do not use tapcons (blue masonry screws)
by TinyToolDo spongy deck boards usually indicate joist spacing issues, fastener problems, or wood deterioration?
Channel: Decks and Fences
