Underlayment Options for Asphalt Roofs
  • DarkKnight
    • 328
    Hey everyone!
    How effective are different underlayment types, like synthetic versus felt, at preventing moisture intrusion under asphalt shingles, especially in areas with frequent wind-driven rain?
  • Alpha
    • 194
    Both synthetic and felt underlayments can help with moisture protection, but synthetic usually does a better job, especially in areas with a lot of wind-driven rain. It’s more durable, resists tearing, and sheds water more effectively. It also stays more stable over time, even if the shingles aren’t installed right away.
    Felt, especially the heavier #30 type, can still be useful, but it’s more prone to wrinkling and doesn’t hold up as well if it gets wet. For harsher weather conditions, synthetic is generally the better and more reliable choice.
    • DarkKnight
      • 328
      Thanks! Do you still need ice and water shield if you’re already using a high-quality synthetic underlayment?
      • Alpha
        • 194
        Even if you're using a high-quality synthetic underlayment, it's still a good idea to use ice and water shield in certain areas. The synthetic layer does a great job overall, but ice and water shield adds an extra layer of protection where it’s really needed, like along the eaves, in valleys, and around things like chimneys or vents.
        What makes ice and water shield different is that it's self-adhesive and actually seals around nails. That helps prevent water from sneaking in, especially during heavy rain, snow, or if ice dams form. So using both together gives you a much better shot at keeping moisture out in the long run, especially in tricky spots.​
        • DarkKnight
          • 328
          Also, are there any brands of synthetic underlayment that work better with certain shingle types, or are they mostly interchangeable?
          • Alpha
            • 194
            Most synthetic underlayments are pretty interchangeable and work well under all major asphalt shingle brands, but there are a few things worth keeping in mind.
            Some roofing manufacturers actually require or recommend specific underlayments to maintain their full warranty coverage. For example, if you're using shingles from a certain brand, they might suggest pairing them with their own underlayment line to keep everything under the same system warranty. So it's a good idea to check the shingle manufacturer's installation guide or warranty details just to be safe.
            Aside from that, some premium synthetic underlayments offer extra features like higher temperature resistance, slip resistance, or better UV protection if the shingles aren’t going on right away. That can be especially helpful in hot climates or if your roof might be exposed for a few days before completion.
            But in general, as long as you're using a quality synthetic underlayment rated for roofing use, you should be fine with most asphalt shingles.
            • DarkKnight
              • 328
              Is there a limit to how long synthetic underlayment can stay exposed before shingles are installed?
              • Alpha
                • 194
                Yes, synthetic underlayment can stay exposed longer than traditional felt, but there’s definitely a limit. Most synthetic types are rated to be left uncovered for anywhere between 30 to 180 days, depending on the brand. That’s one of the big advantages over felt, which can wrinkle or tear pretty quickly if it gets wet or is exposed to the sun for too long. Still, even if the synthetic underlayment is designed to last a few months uncovered, it’s best not to push it. Sun, wind, and rain can still take a toll over time. It’s always a good idea to check the product label or spec sheet to know exactly how long it can stay exposed, especially if there’s a delay in getting the shingles installed.
                • DarkKnight
                  • 328
                  Good to know there's a bit more flexibility with synthetic underlayment, but yeah, definitely not something to leave exposed for too long. This has been really informative. Thanks again for all the input!
                  • carvega_82
                    • Jul 2025
                    Most synthetic underlayment work with all shingles, but GAF FeltBuster or Owens Corning ProArmor are great for asphalt shingles.
                    • DarkKnight
                      • 328
                      Thanks for the suggestions! 👍
                      • daric
                        • Oct 2025
                        From my experience, synthetic underlayment is definitely more reliable than traditional felt, especially in places that see a lot of wind-driven rain. It holds up better over time, resists tearing during installation, and provides a stronger moisture barrier. Felt works, but it can wrinkle or degrade faster. I’d also say the installer makes a big difference.
                        • DarkKnight
                          • 328
                          Thanks for sharing your experience.
