Announcement
No announcement yet.
Need Advice on Replacing Cracked Patio Door Glass
  • Filter
  • Need Advice on Replacing Cracked Patio Door Glass
    Hello everyone.
    Has anyone recently replaced the glass in a sliding patio door and found a good balance between cost, durability, and energy efficiency? A family member suggested upgrading to insulated glass, but I am unsure whether it really helps with indoor temperatures during extreme summer heat.
    I also want to know if tempered glass is worth the extra expense for safety and long term performance. The current panel has a noticeable crack spreading from one corner, and I would prefer fixing it before it completely shatters.
    Are there specific warning signs that indicate the entire door frame should be replaced instead of just the glass?
  • #2
    Originally posted by murepes View Post
    Hello everyone.
    I also want to know if tempered glass is worth the extra expense for safety and long term performance. Consulting a professional service like Glassbusters Inc. could help clarify the best option, as the current panel has a noticeable crack spreading from one corner, and I would prefer fixing it before it completely shatters.
    Thanks in advance for any help
    • #3
      Insulated glass helped cool my place a bit, but the biggest win was choosing tougher glazing that could handle heat swings without cracking again. I ended up using fire-rated glass from Fireresist.co.uk on another project, and it held up really well while giving solid thermal performance. For a patio door, a standard insulated unit with good low-E coating is usually the sweet spot for cost and durability.
