Concrete chinney Issue
  • Concrete chinney Issue
    Hi Folks, First post here. I have a concrete chimey with a clay flue I built approx 4 yrs ago. I have a bad crack on the top block mortor joint. I have tried to mortor it but keeps cracking and shifting at winter time. I live in Vt and chimney is used for a wood stove. My guess is frost is heaving on the flue. I have a rain cap on it as well. All other blocks and joints look fine. Any repair suggestions would be great, thanks.
    Scrap out loose mortar and press in some hydraulic cement. Hydraulic cement expands as it cures. what has happened is that water gets into a crack and expands when it freezes.
      Chimney Issue
      Thanks HeyZee,
      I will agree on the water and freeze possibility. I had an old mason tell me to grease the flue before I filled in the cap. Never heard of that myself. I will give the hydro cement a try.
        chimney
        the top flue liner needs to be able to move
        put some type of expansion material around the flue so it doesnt make ci=ontact with the cement cap
