Stump Removal
  • bubblegummom
    • Feb 2008
    • 41
    Stump Removal
    I would like to get rid of a tree stump that is starting to rot and is just a couple feet from the house, I guess mainly because I'm afraid it will start getting a lot of insects. It is too close to the walkway to have it pulled out. I have a container of Hi-Yield Stump Remover which contains potassium nitrite. You're supposed to drill holes down into the stump, 12” deep, then additional holes 3” down from the top of the stump, connecting with the bottoms of the other holes, then pour the stuff in.
    I'm just afraid that rainwater or something will cause some of the stuff to splash on the house, and then the house will begin rotting. What do you think?
    Loretta
    stump
    hire a tree surgeon company and have them grind it out. they have a machine that gouges out the wood fibers which you can fill in with topsoil.
    • bubblegummom
      • Feb 2008
      • 41
      Stump Removal
      Thank you, HayZee but can they do that when it's right up against a concrete walkway?
        stump
        the grinder is a unit that is under a carriage with an engine atop a rail . the whole thing is on a trailer of two wheels which straddle the stump. In operation the grinder spins at a fast rate and hydraulics move the carriage from side to side and the depth is hydraulically controlled. It chews up whatever is in its path. I wouldn't worry about your sidewalk. Contact them and speak with them.
        • jasonree
          • Jun 2026
          • 12
          If the stump is already starting to rot, the risk to your house is more likely to come from moisture and insects being attracted to the decaying wood than from the stump remover itself. Potassium nitrate/nitrite stump removers are generally designed to accelerate decomposition inside the stump and, when used according to the label directions, shouldn't cause your house to rot if a little rainwater runs off. That said, since the stump is only a couple of feet from the house and near a walkway, I'd be cautious about relying solely on a chemical treatment.
          A professional stump grinding service may be a better long-term solution because it physically removes the stump material without waiting months or years for decomposition. Companies such as RTEC Treecare often recommend grinding stumps close to structures to eliminate concerns about insects, ongoing decay, and root-related issues.
          If you do use the stump remover, follow the manufacturer's instructions carefully, avoid overfilling the holes, and consider covering the stump during heavy rain to minimize runoff.
