So...this house is a bit over 150 years old. Some soldier bricks above a window are very, very loose, as are the two rows above them. Directly over the window. Keeping all bricks in order, I carefully removed each and cleaned it's surfaces. An easy task. It's all vacuumed out with no more chips or loose mortar. I purchased a 55# bag of mortar and took out about 5# and mixed in about a cup and a half of water. First, the mortar will NOT stick to anything!! Second, it started hardening up so very fast that it was not useable within ten minutes. Less than five minutes later it went into the trash as a solid.
What's the correct way to do mortar? What ratio mix to water? I don't want to mix a lot of it at a time. No more than 5#. What's the secret to getting it to stick? Should I pre-spray the brick and adjacent items with water first?
