Well, ambitious...yes, but I think it's the right way to go. I like that idea of removing the decking, especially if it's been damaged. You're right about it opening up the opportunities...The ice dam is a definate requirement here in Michigan. (I'm in Jackson County, was Wayne..) That's a really good plan. THe only places that I would comment on are (from 1st list):
16. Make them flush with the tops of the rafters so as to not kick up the decking. You alluded to that in your 2nd list.
19 and 20 are not necessary. I would think the lookouts would be more a structural need if the overhang were greater than 2 foot.
21. Yes, vinyl is the way to go for this. Very easy to work with and FAR more forgiving than aluminum!
27. Good question. (this means...no answer!)
28. Nail a J channel to the underside of the soffit so that the bottom of the J is against the inside of the facia board and that the short stem of the J is even with the bottom of the facia. The F should then be placed on the wall directly across from that J and the two will provide the parallel channels for your soffit trim.
I prefer to use aluminum for the soffit panels, vinyl for all else. I've had trouble finding vinyl panels with holes punched small enough to keep out the Lady bug type beetles, mosquito's and a few others. The aluminum has a finer brether hole opening that helps keep out these critters. To help your cutting, get a good 2x12x14'. nail some 2x4 to the edges to create a channel. About midpoint build a bridge across that's wide enough for your saw and saw guide. Make sure the guide is 90 to the side rails. Run your saw through the piece and just about an 1/8" into the 2x12. Now you have a nice true saw guide to use for your trim pieces. Reverse the blade in your skilsaw. Use it that way for the vinyl as well as the aluminum. When placing the siding on the house verify where you want the overlaps. They should always be flowing away from the line of sight. Nail up the first piece furthest from the normal approach to that wall of the house. Don't drive the nails hard. The siding needs to float under the fastenrs. Vinyl and aluminum both have a terrific rate of expansion. I don't believe you can over vent the attic. if you use the perforated soffit the entire length would be fine. The ridge vent is a great idea. For the ease of it, just go ahead and do the entire ridge. (this is an opinion....I run the ridge vents right to the roof edge and use the cap ends to seal it. I think it looks much nicer than stopping 2 or 3 feet shy and shingling a slope to the normal roof ridge. My $0.02.)
Are you going to reroof the entire house at this point? Or just the edges you're working on. Would it be possible to do two strips of that ice dam? (By the way, rent a roofing power nailer.)
Get that cold, cold beer.
