I have a rotten 2x10 or 2x12 under my group of windows in the front of my house. The board is one long piece. The windows are wooden with 9 individual panes each. The house was built in 1940. It looks like I have to take apart the frame around the windows outside before getting to this board. Any tips on how to get started? I will try and post pictures Saturday. I don't have that privilege yet.
Wood Rot Under Windows
the windows are probably fastened to the studs on either side of the casing or the mullion [ the piece between two sets of windows] The external moulding needs to be removed first and probably the inside casing moulding too. once you remove this stuff check out the sill [2X whatever] for termite infestation. just poke with a screwdriver. punky wood will give way. the nails that hold the window will have to be cut using a sawzall and a metal cutting blade. take the windows out either separately or as a unit if you can and start to rebuild your sill. use pressure treated this time.
by kemiySo, doesn't the Buyer have the right to get copies of closing docs signed by both the Buyer and Seller?
Especially the Settlement Statement...-
