I have a rotten 2x10 or 2x12 under my group of windows in the front of my house. The board is one long piece. The windows are wooden with 9 individual panes each. The house was built in 1940. It looks like I have to take apart the frame around the windows outside before getting to this board. Any tips on how to get started? I will try and post pictures Saturday. I don't have that privilege yet.
Wood Rot Under Windows
the windows are probably fastened to the studs on either side of the casing or the mullion [ the piece between two sets of windows] The external moulding needs to be removed first and probably the inside casing moulding too. once you remove this stuff check out the sill [2X whatever] for termite infestation. just poke with a screwdriver. punky wood will give way. the nails that hold the window will have to be cut using a sawzall and a metal cutting blade. take the windows out either separately or as a unit if you can and start to rebuild your sill. use pressure treated this time.
by AlphaWhat’s the best way to prep roofing to avoid ice dams and leaks?
