when my home was built, the plans called for the gutter on one side of the hose to be approximately 70 ft long with a downspout at each end draining into a pipe connected to the storm drain.. I have been told that once the house was completed, the builder had forgotten to run an underground drain line from one down gutter downspout to the storm drain so the owner thought that if the gutter was angled down right, one downspout would be enough.. He/she was wrong.. When I bought the house I saw that one downspout was not able to handle all the water in a heavy rain.. Since the area that an under ground drain line would have to be installed in for a second gutter on the other end, was now covered by concrete, that was out of the question.. SO.. I installed a downspout in the middle of the gutter and it drains into a rain barrel for collection and then on to the storm drain with a 1 inch pvc drain line. Never had any problems EXCEPT that the end of the gutter without a downspout is a little lower than the middle section of the gutter is so it retains water as I hope the picture shows.. I have thought about just raising this end of the getter a little BUT worry that the gutter nails/screws would be very close to going back into the same holes they came out of thus would not work.. QUESTION.. Ideas on how to do this, or would it be expensive to just have a gutter company remount the the gutter at a proper drain angle or even replace the gutter? Thoughts
Gutter Drainage issue
I'm having issues with my gutter drainage. I've attached some pictures and last image shows the set up. Ground floor flat in victorian conversion in North London. ISSUE 1 - There's always water in the bottom of the drainage. I noticed it for the first time during heavy rain as it sounded like it was draining into a puddle. Pulled up a slat of the decking, removed as much silt as I could. Feeling around it feels like it drains into a U bend. Is this why it's not fully draining (Like a toilet?). Is this something to worry about? ISSUE 2 - I also noticed there's a bit of the concrete missing and underneath there's just clay soil. All the water from the bay window gutter just fall into the soil bit, pools and eventually overflows into the drain. I've stuck a skewer into the soil and it goes down about 10cm/4inches before hitting something solid. Is this an issue? Is this an easy DIY fix or does it need a pro? If it is a DIY fix what do I need for it? Thanks!when my home was built, the plans called for the gutter on one side of the hose to be approximately 70 ft long with a downspout at each end draining into a pipe connected to the storm drain.. I have been told that once the house was completed, the builder had forgotten to run an underground drain line from one down gutter downspout to the storm drain so the owner thought that if the gutter was angled down right, one downspout would be enough.. He/she was wrong.. When I bought the house I saw that one downspout was not able to handle all the water in a heavy rain.. Since the area that an under ground drain line would have to be installed in for a second gutter on the other end, was now covered by concrete, that was out of the question.. SO.. I installed a downspout in the middle of the gutter and it drains into a rain barrel for collection and then on to the storm drain with a 1 inch pvc drain line. Never had any problems EXCEPT that the end of the gutter without a downspout is a little lower than the middle section of the gutter is so it retains water.. I have thought about just raising this end of the getter a little BUT worry that the gutter nails/screws would be very close to going back into the same holes they came out of thus would not work.. QUESTION.. Ideas on how to do this, or would it be expensive to just have a gutter company remount the the gutter at a proper drain angle or even replace the gutter? ThoughtsLast edited by admin; 08-06-2026, 08:33 AM. -
Hi there!
If you’re still dealing with the issue of water pooling in your gutter, adjusting the angle might be a good solution. You could try raising the low end with new brackets or screws, ensuring you don’t reuse old holes to maintain a secure fit. If you're not comfortable making these adjustments or if the gutter shows signs of wear, it might be worth calling a gutter company. They can provide a proper fix, whether that’s adjusting the current setup or replacing the gutter entirely, which could be a good investment to prevent future problems.Comment
by kemiyHello all. I'm in the midst of planning a much-needed makeover for my home's interior, and I could really use some expert advice and creative ideas. My...
