Hi all! Can someone explain the difference between caulking and sealing? When should each be used, and are there specific products that work best for different situations, like around windows, doors, or cracks in siding?
Caulking vs Sealing
Hi Downaski!
Caulking and sealing are often used interchangeably, but they have some key differences. Caulking is typically used to fill gaps, cracks, or joints to prevent air, water, or pests from getting through. It's more flexible and is commonly used around windows, doors, and baseboards where movement might occur. Silicone caulk, for instance, works great in bathrooms or kitchens because it resists water and mold, while acrylic latex caulk is ideal for painting over around trim or siding.
Sealing, on the other hand, generally refers to applying a product to cover and protect a surface. Think of it like a shield—it’s used for larger areas to make them water-resistant, airtight, or stain-resistant. Sealants are often applied to concrete, wood, or tile surfaces to prevent moisture damage or stains.
For your specific examples, around windows and doors, caulking is the go-to to close gaps. For cracks in siding, a flexible outdoor sealant might be better since it can handle exposure to the elements. Do you have a particular project in mind?
Thanks for breaking that down! I didn’t realize how much versatility silicone caulk has, especially for kitchens and bathrooms.
As for projects, I’ve been thinking about sealing up some small gaps around my windows and maybe tackling a couple of cracks in the outdoor siding. Do you have any favorite products you’d recommend for outdoor sealants? Also, how often do you usually reapply caulk or sealant in areas like these?
Would love to hear your tips!
You're welcome! Silicone caulk really is a game-changer for those kinds of projects, super versatile and long-lasting.
For outdoor sealants, I’d recommend going with something labeled as weatherproof or made specifically for exterior use. Polyurethane sealants are great too since they’re super durable and can handle expansion and contraction from temperature changes.
As for reapplying, it is better to check every couple of years, but it depends on the weather and how much wear the area gets. If it still looks solid and there aren’t any cracks or gaps, you’re probably good to leave it alone.
What kind of siding do you have? That might help narrow down the best product for your project!
Thanks for the tips! I’ll definitely look into weatherproof and polyurethane sealants. They sound like they’d hold up well, especially with temperature changes.
I am asking for vinyl siding, so I’m guessing flexibility and durability will be key. Do you think polyurethane would work well with that, or should I stick with silicone for better adhesion? Also, checking every couple of years makes sense. Good to know I don’t have to overdo it unless there’s visible wear.Comment
I'd actually recommend a high-quality silicone caulk. Vinyl siding naturally expands and contracts quite a bit with temperature changes, and silicone is better at flexing along with it without cracking or losing its grip. Plus, silicone bonds really well with vinyl. Just make sure you get one that's specifically labeled for exterior use and vinyl siding. Some silicone products are even labeled "siding and window" which is exactly what you want. You'll want the kind that says "100% silicone" rather than a silicone blend, since those tend to hold up better against the weather.
And yeah, the inspection schedule is pretty forgiving with silicone - checking every couple of years is plenty unless you notice any drafts or see visible gaps. When you do check, just keep an eye out for any spots where the caulk might have pulled away from the siding or looks dried out and crumbly. Those are your signs that it's time for a touch-up.Comment
by aspenmathewMy log splitter won't start, pulled the cord probably 30 times, it's not new but always ran fine before. Any idea what I'm missing
