Amarr Insulated Garage Door Parts
  • hrr57
    • Mar 2011
    • 5
    I have an Amarr double car garage door and both doors are in need of replacing the rubber seal at the bottom. The type that I have is an aluminum strip with the rubber edges of the seal inside a channel on booth edges (in and out) of the strip.
    Anybody has any idea as to where can I buy these parts? Second, how do I remove the old seal for replacement? Thanks in advance.
  • Door_Tech
    • Mar 2011
    • 6
    Amarr.com
    Find a local dealer thatcan sell you the bottom rubber. The problem with the Amarr bottom seal is that it will shrink over time leaving a 4" gap on one side. Your best be it to get a little more than you need and fold the excess bottom rubber inside
    • hrr57
      • Mar 2011
      • 5
      Door_Tech,
      How can I remove the old bottom rubber, just pulling it out or are ther any screws? Thanks for you replies.
      • Door_Tech
        • Mar 2011
        • 6
        It just slides out one side
        Hopefully there are no screws in the T-rail but you should have no problem switching it out yourself. A little silicone lube or liquid soap in the rail will help too
