Custom Metal Building Advice Needed
  • shen.151
    Banned
    • Mar 2026
    • 24
    Hi everyone,
    I'm planning to invest in a custom metal building for my property and would appreciate some guidance. I'm considering it for storage and possibly a small workshop, but I'm unsure about the best design options, insulation choices, and long-term maintenance requirements. How do custom metal buildings compare in cost and durability to traditional construction?
    Are there specific manufacturers or contractors you recommend? Also, what should I watch out for in terms of permits, weather resistance, and foundation work? Any personal experiences or tips would be greatly appreciated as I begin this planning process.
    Thanks in advance everyone here.
  • jovenac
    Banned
    • Apr 2026
    Custom metal buildings are a cost saving and durable option compared to traditional construction offering quick installation and strong resistance to weather fire and pests. Some builders also consider a China custom metal building option for lower upfront cost but quality varies so choosing a reputable supplier is important. Proper insulation is essential spray foam works best for sealing air gaps and controlling moisture while fiberglass is cheaper but less effective and rigid foam is a middle option. A reinforced concrete slab foundation is recommended for stability and proper load support. Always check local permits and building codes including wind and seismic requirements before starting. Maintenance is generally low and mainly involves checking for rust sealing issues and roof fasteners over time.
    • Chunkypigs
      • May 2026
      Originally posted by shen.151
      Hi everyone,
      Are there specific manufacturers or contractors you recommend? Also, what should I watch out for in terms of permits, weather resistance, and foundation work Revit quantity takeoff services? Any personal experiences or tips would be greatly appreciated as I begin this planning process.
      It’s important to think beyond the present—consider expansion options, local weather conditions, and energy efficiency.
