My door and opener have worked fine for the 20 years I've owned the home. Never had an issue.
Someone left a box in the path of my garage door, causing the door to get stuck closing. The box was sitting outside the door so the safe-t-beam couldn't see it. This caused both the fuse on the motor control board to blow (as it it designed to do) and also caused the logic board to fail (original board).
I replaced the logic board with the Genie recommended replacement (36600R.S) and replacing the fuse with the correct replacement. Every wire and ribbon cable were checked for correctness. Door was checked for being true and properly balanced. Tracks and hinges re-lubed. Springs were replaced by a local garage door company 5 years ago.
Now, when I plug the opener in to power, it starts to open immediately at full speed (not the gradual learning that it is supposed to do). it only opens about 18" (one panel) and then stops, giving a single blinking green LED. If I wait and plug it back in without closing the door again, it does the same thing... 18" and stops.
Also tried the same processes above without any sensors or switches connected. Same results.
Google AI suggestions point to the automatic unbalance sensing of the opener, yet the door checks out as being properly balanced.
I'm at a loss as to where to look next. Any help or suggestions would be appreciated. I'd like to avoid a service call for something small and dumb.
