I recently replaced my door opener and adjusted the tension on my torsion springs. While adjusting the tension, I had trouble finding the right amount. When lifting the door a few feet off the floor, it falls back down indicating that there is not enough tension on the torsion springs. But when I try to close the door, it doesn't want to go all the way to the floor unless I push down on it. And when I let go, the door springs back up about a half inch. Likewise, with the opener connected, the opener has to push down on the door to get it to close completely until there is slack in the belt (probably not a good thing for the opener).
Are the springs in need of further adjustment or replacement? Something tells me this might rather be an issue with the pulleys and/or cable lengths.
Any suggestions would be appreciated.
Thanks
Thanks
