I have trouble with water coming in under my door and I purchased a ultra rubber bottom seal online with a rubber tube on the inside of it and the rubber itself is thicker.
The door now tries to close but the goes back up - I have adjusted the force on the motor to the most it will go - can you adjust the strength the door closes with more with the torsion bar or spring?
I just cant believe I cannot get enough pressure out of the door to mesh down a thicker rubber seal
any help is greatly appreciated!
