craftsman upper limit issue
  • stogies44
    • Aug 2012
    ok, I am going crazy. I hope this forum is the last one. Craftsman opener will close and open properly but hits the bolt at the top. I have checked the connections (good). I have adjusted the upper limiter from all the way back to as far forward as it can go and half turns all the way in between. When I remove the yellow wire from the upper limiter the door wont work so I know there is power to the wire. I have rapped bubble rap for now onthe bolt so it doesnt bang as hard but what could it be?
    I have a few parted openers that I use for my extended family when they have issues but just cant figure this one out. The lower limit works just fine and I can adjust it any way I want but not the upper.
    HELP ME
  • GarageDoorRepairGuy
    • Aug 2012
    • 17
    It might be a corroded contact, which is common in garages near salt water or where pool chemicals are stored. Try cleaning the contacts with a small nail file. If that doesn't work, then try replacing the RPM sensor, as the limit switch wires travel through that.
    Garage door repair, installation, openers, and screens across Central Florida. 20+ years, 9,000+ 5-star reviews, and no service call charge.
    • stogies44
      • Aug 2012
      fixed
      so had a few parts and compaired each area. It turned out that the little piece of metal on the limiter was broken off on the up side. So I took a limiter from another model and replaced it. The garage works the way it should now.
      Thanks for the advice. Hope this helps others.
