I bought a house with a Genie Screw Garage Door Opener (1/2 H.P. IS900/A) that had terminal strip wires disconnected. Following the Genie Manual, I managed to connect the STB sensors and the wall control and the door opens and closes fine using the wall control. Issues:
(1) I cannot figure out how to connect the wired Genie Intellicode keypad to the power head since the manual is silent about the wiring for a wired keypad. What terminal numbers do the white & red (striped) wires of the wired keypad connect to at the power head? Help.
(2) Does anyone know what remote controls work with this Genie Screw Drive 1/2 H.P. IS900/A opener? I was given a one button Stanley A9K XMULTI-CODE remote to use on this opener by the seller but I am failing to program it by following the simple instructions in the user's manual. The red learn indicator keeps blinking about 2 times per second when I press the remote button once within 30 seconds. Could I be doing something wrong or this remote is not compatible with the opener?
