About a year ago I replaced the garage door opener with a Genie model. Everything has worked fine up until recently. What happens is, when I open the garage door, the safety sensors die. The red light goes out completely. This doesn't happen every time, but has happened 3 times in the last week or so. I unplugged the garage door opener and checked on the wiring. Unscrewed the wires at the safety sensor base, readjusted them and re-tightened. Plugged the garage door opener back in and the light on the sensors was still off. unplugged the unit back off for about 10 minutes, plugged it back in and the light turned on and I was able to close the garage door. Is it the wiring or are the sensors going bad? How do I find out what's causing the problem?
I also noticed that when I plug-in the garage opener into the outlet, there is a brief spark. There are actually black melted marks on the prongs of the plug. I read that a brief spark can be normal for some electric devices? Doesn't sound normal.
