Garage door opener cold weather!
  • douflyfish
    • Jan 2010
    Have had 3/4 hp Craftsman garage door opener in house for past six years with no problems except this winter! When the temperature drops below 32 degrees garage door will not close with remotes. Only closes by holding wall-mounted control Any ideas on resolutions.
    Thanks!
  • gdoorpro
    • Jul 2007
    • 129
    sensitivity setting
    You need to adjust the close force setting. This is found on the motor where the wiring runs into the motor. Their will be 2 little blue screws with a #dial from 1-9. Turn the one labeled down a little and try operating the door. Adjust incrementally till door operates consistently.
    Ryan
    • douflyfish
      • Jan 2010
      Though I haven't made the adjustments as you've recommended in your reply to my "garage door opener cold weather" post; I do very much appreciate you taking time from your busy day to reply. I'll post the outcome after I've made the adjustments.
      I'm looking forward in making the adjustment to ascertain whether it will resolve this issue.
      Thanks
      Douflyfish
      Last edited by douflyfish; 01-14-2010, 09:18 PM. Reason: Attempting to apply thanks button!
