Top panel of garage door jamming when closing! (have a video)
  • yunaiseng
    I made a video to show what's going on:
    youtube . com/watch?v=4mKGEs3kihY
    (sorry for the broken link, I guess I'm prevented from posting links since I'm a new user to avoid spammers)
    In takes #1, #3, and #5, I push forward at a speed that seems to be enough for the momentum to "pull" the garage all the way closed. But the speed I'm pushing at is faster than the motor runs. In takes #2 and #4, I push at the speed the motor would push and when the garage is almost completely closed, the last panel just jams. When its connected to the motor, it actually begins to badly bend the top panel of the garage.
    I've reinforced the horizontal stiffener that runs across the top of the garage. I've also reinforced the vertical bar on the garage door that the motor arm is attached to. I've also bought garage door lubricant from Home Depot and sprayed down the rails, the wheels, and the chain. That seemed to help a things a bit as far as smoothness, but it still jams when it gets to the last panel during the closing! (when not moving at a faster speed)
    I'm kind of going crazy. Any ideas on what else I need to check/replace to fix this thing?
    Thanks!
  • gdoorpro
    • Jul 2007
    • 129
    sometimes an operator will cause the door to get closer to the jambs at the 3rd sectional joint, causing it to rub against the jamb a little too much. You can bring adjust the track farther away from the jambs to help out in that situation.
    If you have stress fractures in the 3rd section you may need a strut for reinforcement, like the top section.
    if you email me the link, i will take a look at it. My email is in my user profile.
    ryan
