this is a copy of an email I sent to Genie...I'm just pasting it here to try and get some immediate help...TIA
I have a Promax Chain Glide 2 garage door opener. Just recently it is having issues opening and closing. It appears as if there is a short somewhere. An example of the problem:
Either opening or closing it will suddenly stop. If I push the button again it will go in the opposite direction. Sometimes it will go all the way, other times merely inches. It had been doing this for a week or so until just the other day when it would stop and there would be no power on the opener buttons in the garage. If I tapped the opener, the lights on the buttons would come on and I could attempt to open it again, sometimes with success, sometimes not. It will now no longer has power.
I have verified that there is power to the outlet it is using. I also have verified power to the circuit board by testing volts on the back of the circuit board at the soldering points of pins 7 & 8.
I have tested continuity between pins 1&2, 1&3, 1&9, 9&2, 9&3
I have also tested continuity at terminals 1&2 with the button depressed.
I am thinking that the problem could be either
1) bad circuit board or component
2) thermal switch overloading
3) problem with the motor
Probably most likely the circuit board because of the power not coming back on. I unplug the power and reconnect it and the unit still remains off. I would not think #2 or #3 would cause there to be no power.
I would like to get some advise on what else I can test and any ideas of what may be wrong.
Thank you.
Thank you.
