My garage door bottom two panels are buckling and cracking. The door hangs up at the curve in the rail and I have to play around with the closer to get it to close completely. Would running an angle iron brace across the panels help? It settles to the floor easily so I don't think its a pressure issue, the panels just seem to waffle back and forth
Bottom two panels buckling
Yes, reinforcing the section with a strut will help out. I would recomment you put it as close to the top and bottom of the section.
There is a problem with this though, because it will change the wight of the door and thus throw off the counterbalance provided by the springs.. You can buy replacement sections, but often times it is better just to buy a new door.
I recommend a strut on each section for all doors that are 16' wide or wider. Struts should be placed as high as possible on each section just below the hinges.Comment
